- Oct 17, 2008
A fresh Otter from Germany. Thanks Dad!
Thank you. I have been working with the edge. It came sharp, but not as sharp as I like. The zero grind is a bit problematic. I attached a sheet of 2500 grit wet sandpaper on a leather strop glued on plywood so I have an even surface. It is slow with a stropping motion but I'm getting a shaving edge. I want an edge that I can maintain stropping on leather. Now to make a sheath.Smashing work !!! Love the look of it...wow!!
Happy Fathers Dsy Shawn.I hope to see this thread busy today with many Father's Day gifts! Happy Father's Day!
Awesome. Happy Father’s Day!I hope to see this thread busy today with many Father's Day gifts! Happy Father's Day!
Thanks Perry!That's a great Father's day, Ron!
The earliest runs of the 127 UH and the 227 UH had covers that were MUCH thicker, sorta like we think of when we hear 'fat stag.' They changed this fairly quickly. This example was #00456, maybe the first day or two?
Interesting to me Cal that the S-W is in stainless, from even that early on. Beautiful knife!
African Warthog Fontenille Pataud
View attachment 923449 View attachment 923450[/QUOTE
https://goo.gl/images/9H4EG9
Wurrwulf
I didn't until you mentioned it. It IS a tad heavier. I know that G10 and bone are not that different in density, so I got out my calipers and found that, while the blade stock is the same thickness at the tang, the Carhartt blade is thicker as you go out from the tang. Half an inch from the stepdown from the tang, the CV blade is 0.85", while the Carhartt is 0.91". Also, the Carhartt blade is a bit wider, as you can see in the photo below.
And while the tangs are the same thickness, they are shaped differently, with the Carhartt having more material on it.
I had looked up the Case promo material for the Carhartt series before I bought the knife,
"Each knife in the collection will feature Tru-Sharp™ surgical steel blades with a Strong Shoulder Grind, Case’s special grinding process that gives added strength and rigidity to the knife blade at the tang area. .I couldn't figure out what they were talking about with that "strong should grind" comment, but now looking at it, I do. By Golly, either Case used new dies for fine blanking these blades or they are machined instead of stamped. Either way, no wonder the alignment is spot on.
... the stainless steel blades will also feature a Scotch-Brite™ brushed finish."
So the blades are a tad wider, a tad thicker, and the tang is shaped differently. So, yes the knife is heavier.
You know, while a lot of folks like to ooh and ah about covers, it's the fine points of the design of a knife that turn me on. I find this knife to have a really interesting set of design choices. To me the differences on this knife are kind of like using a tuned exhaust on a roadster to get a bit more oomph out of the engine. You don't really notice it when you look at the car, but it drives better. It's very cool.
