I use to have lots of knives. Now I mostly have Winklers. My Blue Ridge Hunter and SD1 get the most use as my hunting knives. I haven't had any issues with the steel and I have no problem cutting up game.I just started looking into Winkler and recognize some of you from other brand sub forums. So, for the guys (like me) who don’t own a Winkler but are interested, how does the steel perform in comparison to your other knives? I have looked at a lot of reviews on YouTube but they are mostly just a showing of the styles and in some cases comparing one model to the other but not much in the way of how the blade performs and how much use between edge touch ups. They look fantastic. I think they look old when new (in a good way). Possibly vintage is a better term. I have other fixed blades that perform really well but nothing with this level of old school character. Have you moved away from some of your other blades once you tried Winkler? I’m always trying new ones and have a SD2 in tribal maple in the mail as we speak. Thanks in advance
I’m not familiar with the Spyderco sharpmaker but it looks like the 30 degree gauge in your picture translate to 15 degrees per side, which is how I like to profile my winklers. You could probably go thinner too if you wanted, 80CrV2 is quite tough and should be stable even with a very acute edge angle.I’m new to paying attention to edge angles. 15dps is that what i call 30 on one of those edge angle tools? My sharpmaker that i like a lot has angles of 30(15 each side) and 40(20 each side)
On my gauge is the 15 on it the 15 dps you mentioned? K kafolarbear ?
I’d say it’s worth it, especially if you have one that’s not cutting as well as you think it should. I’m yet to have any chipping issues and the boost to cutting performance is noticeable.So i’m at 40 on the Sharpmaker which is 20 on the gauge so i could attempt to go 15 or the steeper angle (30) on the Sharpmaker. at least with one of my winklers just to see how i like it?
Yeah I’ve definitely gotten 25+ DPS from the factory. I actually ended up talking to Daniel Winkler over the phone one day and asked him about it, he was quite insistent their edges should come around ~18 DPS which clearly wasn’t the case.Seems when i asked which angle on the Sharpmaker to use i was told 40 as the WK’s are hand sharpened by different people and vary often exceeding 40. When i sharpened my BRH for the first time it must have been over 40 because after it did seem sharper and a little closer to being a slicer. Still wouldn’t use it on a soft ish tomato. Firm fruit and veg no problem.![]()
This is all good to know. If you can take a picture of this mico bevel on the knife or the wide edge you speak of it would be appreciated. If not no big deal.
Page 27, post 535Had the Edge Pro out a couple of days ago, desided to give the belt knife a treatment. First time I used the Edge Pro with this knife was when I got it a couple of years ago. I settled with the 18 deg setting back then. The bevel got a bit wide, but I had read that it was a thick knife, thick behind the edge etc.
This time I just polished up the bevel, started with the 600-stone and up, then stropped. I tried to use the same setting as I did last time two tears ago, but the bevel got a bit steeper than last time I did it.
After I used it today, I wanted to test something: I used a sharpie on the bevel, took out my Sharpmaker, put the rods in the 15 deg setting, and gave it a few swipes. It made a barely visible micro-bevel. I mistakenly sharpened it to far below 30 deg inclusive.
So up until now I have used it with an angle lower than 30 inclusive, and it has been used a lot, mainly on hard, dry wood. During these years I have only stropped it to maintain the edge (with some rather heavy compounds), and it has not gotten any damage. I am impressed!
Perfect composition. It looks like it’s exactly where it should be.
