The toughest job i did with it was cut cardboard, wood and rope, but probably what did it in was me leaving it around my garage while working in there.
How does all that internal damage occur by sitting in your garage sir?
Just a quick question to CRK: Can the blade play be stopped just by putting a bigger stop sleeve in? I understand your position, just wanted to know the details about what goes into the $150 repair cost.
Let me make a comment about "flicking". I doubt everyone using the term means the same thing by it. I have owned five Sebenzas and never had a problem with flicking because the only flicking I did was with my thumb to the thumblug. This snaps the blade open, but the tight tolerances tend to damp the opening speed and the blade will just barely lock in place.
The childish version would be to open the blade slightly and then with a hard centrifugal motion slam the blade open into the stop pin.
That's the kind of Flicking that Mr. Reeve has said will have a longterm deleterious effect on the tang and pin. Why would you expect unnecessarily hard metal on metal contact to be considered anything but abuse?
If you do it once or twice, open the blade and wrist flick it to lock, you aren't damaging the knife noticeably. But continued showing off is not what a working knife should be built to withstand.
I am not implying that they are fragile, I am saying that if i put the knife through such abuse than the blade would have been chipped.
the blade being hollow ground has nothing to do with the edge chipping.
sorry dude, this makes no sense.
you are lying, perhaps by ommission, but lying nonetheless.
no, if the stop sleeve/pin were larger, the blade would not lock open. it would stop short when it hit the sleeve.
I'm talking about stop sleeve/pin just bigger enough to fix the problem without preventing opening. I know that CR is famous for his tight tolerances. I just don't know how cost effective that is etc.
I think I have read somewhere that Strider put in a bigger stop pin to fix the blade play.
how could cutting rope, wood, and cardboard result in damaged bushings?
did he stick a screwdriver in between the blade and scale?
he likes knives shaving sharp, but clearly isn't very skilled at sharpening.
he did something he is not telling us, all the pieces of the puzzle don't fit.
Unless of course it is the company CEO that is making the decision based on years of experience to recognize what he is seeing. Making the point to the mall ninja world that if the Sebenza has a flaw it is that it doesn't like to be wrist flicked all day long...so either don't do it or don't buy it.It really sounds like a bad business practice, if what you say, in fact, happened.
