I would ask the shop on that one for the specific knife![]()
Done. You don't know where I could find a pic of a DC CGBJ do you? Thanks!
-Emt1581
Is there an extra charge for double cut? If so any idea on a ballpark figure for the CGBJ?
I'm really only buying this to check out the INFI. Still I do like the double cut finish slightly better than the black.
Thanks
-Emt1581
Double cut is usually a bit more expensive, as the knife must first be finished to a satin before the bead blasting.
-Emt1581
There is definitely an extra charge for double cut. The Combat Grade BJ's prices for finishes added $60 for that finish.
Better hurry if you want to change it... you ordered quite a while ago, didn't you? Double cut is my favorite finish. It's almost silvery in look and in feel, not as dull gray as photographs make it appear. The only issue is rust. It's still such a non-issue regardless, especially since you can send it back under warranty (I think) and since you got Kydex (Jaxx reported leather sheaths having a bad effect on his double cut blades).
Well either way you go I know you won't be let down. I do prefer DC and Satin, but thats not saying I don't like the coatings too. If you aren't going to beat the snot out of your knife through logs, I have found coatings hold up well. Some better then others though
Good luck deciding.
Coated:
-Can rust under coating
-Coating can get material imbedded in it
-Coating is harder to keep clean / irrelevant point if you don't plan on any food prep
-Coating can look like crap / Unless you like the worn look
-If you really use the knife, the coating is going to come off
DC:
-More reflective then a matte black coating
-Can show wear
-wear can lead to satin/higher reflectivity
IDK man, just off the top of my head. I don't worry about the tactical thing so I usually go Satin. Probably best to let a tactical guy chime in on this one.
I like satin (which you don't want), because its easy to keep clean, wears the best out of the bunch. Satin is just uniform scratch patterns you know.
You can take a satin blade and beat the crap out of it, spray some WD on it and wipe it all off and be good to go.
I am just saying this so you can basically pick and choose my opinions as you wish.
The BOSS Jack Combat grades will be .220" thick with a Full Height Convex ground bevel. Convex grinds are typically difficult to sharpen properly when coated because in order to effectively sharpen them you have to remove approx 1/4 - 1/2" of the coating above the edge.
The good news is that we have developed a new procedure where the blades will be zero edge sharpened just prior to coating. Then, we only need to remove a small amount of the coating before honing and stropping! :thumbup: :thumbup:Seems to work great!!! . . . :thumbup:
The combat grade blades below DO NOT have this new edge, but they will give you an idea of a few color combos as well as show how killer cool these BOSS Jack blades really are!!!!! :thumbup:
Here are a few sample pics. . .
The Limited Editions will be .180" (Less than 3/16" thick) with a flat sabre grind :thumbup:. . . . Anorexic baby!!!! :thumbup: :thumbup: . . . They will have a blended zero edge. . . . Here are a few sample pics. . . .
Coming soon!!. . . . Barring any unforeseen circumstances (which there always seem to be) they should be up either late tonight or early tomorrow morning. . . . .
Let's Drink! :thumbup:
Jerry
