STR said:
The only difference between CS and the others is that the owner is a ...
Take a look at how Spyderco promotes thier knives :
"A cornerstone in Spyderco's
Save and Serve line up, the Military Model came about after someone asked Spyderco\'s owner Sal Glesser, "If your son were going into the military what folding knife would you send him with?" For certain, it had to meet the requirements of a high-performance, light-weight folder designed for hard use."
There is a big difference between that and how Cold Steel promotes their products. As noted lots of people will actually support the performance claims they make.
I challenge anyone to get an Ultimate Hunter from CS and tell me with a straight face that it is crap.
No one is arguing that.
STR said:
So if a TMB even begins to approach a custom hand forged blade say twice or three times the price is the above statement hype or truth?
That arguement contradicts itself immediately. All you have to do is take something much cheaper and do the same performance/cost ratio comparison and the Trailmaster will get mauled.
But who measured any of it ...
Cold Steel I would assume since they said it initially, lots of other measurements of various types can be found for lots of other knives, as I noted Turber did them directly. Lots of ABS guys do tests for sharpness and cutting ability, video's and pictures are available on the web. Some of them are much more impressive than what Cold Steel does.
I guess you won't be happy until Cold Steel says 'Ok, you can put it in a vice and try to break it if you want and if it breaks we'll cover it under warranty'.
No, it if breaks before it was described it should be covered, assuming the break was used to promote the knife.
You think they should allow the user to do anything done in the video and they should have to cover it.
Yes if the results are significantly different. If you get the same thing then it isn't covered of course, you got the expected result. Same thing with any use in general.
STR said:
Cliff if you feel that way why did you even review the Recon Scout and the Trail Master Bowie in the first place?
There are lots of knives I would work with if someone donated which I would never actually buy, there is a rather large difference between the two. If I buy a knife and it fails to perform the way it was promoted and the maker supports the claims I just get a refund/replacement, if they don't support it and it was donated well all I am out is the time, and generally I learn enough from the reviews to make it worth my time.
However I am not going to spend money to investigate performance that a maker won't support. I'll spend my money on knives with high performance claims that the makers actually support for the obvious reasons noted. It is also much more likely that you actually see the claimed performance if a maker is willing to publically support it for obvious reasons.
If the idea was a farce why did you do the review?
As noted there is a big difference between buying something and having it donated. It is however highly insensible to go out and buy a product to see if it lives up to the performance claims when the manufacturer won't actually support said claims and in fact directly states that if you attempt to do so it voids the warrenty on the product.
Plus that review was one of the first ones, if I was doing it now it would be different, one of the first things I would do would be to get the newest DVD and attempt to duplicate the work done. I was not even fully aware of the exent of the hype back then, nor had used the knives I have since then which allow the above statements to be made.
-Cliff
