So, my Kiser Klecker has arrived. I am going to do this first impressions as the bad and the good points that I see and that appeal to me. I will try not to gush, which I have a tendency to do sometimes.
BAD
- as already mentioned a few times, the proprietary pivot
- metric screws, if you do not have metric tools
GOOD
- out of box everything is centered
- scales fit flush with no gaps
- opening is smooth throughout the entire arc
- lockup is excellent, with the liner edge being completely covered and the liner and blade tang are flush with one another on the left side leaving plenty of room for wear, and it takes a strong push to unlock, not sticky, just strong
- blade grinds are even from back to tip, symmetrical, and razor sharp
- clip can be placed for tip up carry, which I did
- ceramic detent ball, bad/good?
- in the last 1/4" of closing it is like the blade is sucked down and the liner snaps over to keep it closed
- blade has a nicely done stonewash finish
- the three backspacer's are machined on the ends so that they fit into the liner's, make for stronger construction? i would think so
- bronze washer's
I took the knife apart to clean up the grease that was in the pivot. I have a small pair of pliers that are padded with thin leather and I used this to take the pivot screw out. Once apart, I cleaned out the grease and applied a little Miltec. I reassembled the knife and switched the clip to tip up carry.
I know I got my money's worth, and think that this knife produced anywhere else might double in price, of course I have NO way of verifying this statement, it is just what I think after handling and playing with it for all of two hour's. Long term will tell the tale. But no more than I will need to use this knife, I doubt that info will come from me.
I am very encouraged that this is a well built knife, and I look forward to getting the Gingrich designed GTi next week since I just placed my order for it.
Hope I was not "gushy" in my account of this knife, and take it for what it is worth. I've had plenty of good knives to go through my hands, and I do count this one in that group.:thumbup:
