- Sep 23, 2006
So if nearly half the 1095 blades that are brine quenched end up cracked or whatever, wouldn't the other half be on the verge of cracking or have micro-fractures already? I am just thinking, wouldn't a less-than-perfect oil quench where not all the pearlite has transformed be better than a blade that was quenched in the brine and may contain fractures? This may be a stupid question, but that is a mark of intelligence in the making. If pearlite is basically un-hardened steel, then wouldn't having a small amount of it in the steel matrix of a hardened blade be a potentially good thing? Wouldn't it make for a more flexible, tough blade? Kinda like having hard and soft steel folded together to make a stronger steel? Go ahead, I'm ready for whatever sarcasm you have to deliver......Let me just get out those dixie cups......
Tougher, yes, more flexible, no. Ductility and flexibility are not the same thing. The only way to make a blade more flexible is to grind it thinner. This is because when you flex a blade you are actually stretching the steel on the outside radius of the curve. Thus, you rely on the elasticity of the steel to return that stretch true. The ability of steel to stretch and return does not vary by composition or heat treat.
However, your point is on the right track as far as it goes. Given that most of us hobbyist scale makers don't have fully optimal equipment, if you have a choice between having some fine pearlite or retained austenite mixed into the steel, or having a network of fine microcracks, I can't think of a single maker I know who would pick the cracks.
The whole point of this thread, however, seems to me a refutal of the idea that this is a choice even us sub optimal hobbyists have to make. If our austenizing temperature and soak time are appropriate for the steel we are treating, and the quenching rate is similarly appropriate, the point is to convert to something approaching 100% martensite, without the stress cracks.
Take away the appropriate austenizing, soak, or quench rate, and substitute it for something less than appropriate, and you are back to making sacrifices. This is where Kevin gets on his soapbox, as the claim is so often made that you can improvise, make do, and use various methods that may or may not provide that measurably appropriate heat treat and still not make any sacrifices. When people deliberately stick their heads in the sand, and then continue to spout off about the superiority of their voodoo magic, it tends to get under his skin, which is almost always educational for the rest of us to watch.
