Emersons are damn near or more money than zero tolerance, use g10 and liner lock that is over come by spinewhacks, and has154cm but your not trolling against them are you ? At least zt will send free clips,screws,bolts,nuts, and has free warranty. Oh and emerson claim to be 1# hard use knife in the world...
Your more knife for the money argument doesn't just apply to zt does it?
Axis lock is very strong but has omega springs that WILL fail, its only a matter of time.....could be 4months or 10 years anyone's guess.
Every lock has pro's and cons, I prefer frame lock to back lock (tri-ad) for ease of disengagement. I own several cold steel ak47s and have had a few zts currently a zt0620cf in my pocket.
Your logic against zt applies to other manufacturers do you voice your same disdain for them as well?
Notice that I didn't mention Emerson for a reason. I have said repeated times that if cost-effectiveness is your concern, then Emerson production knives are not the way to go, due to all the issues you mentioned. I don't see how not mentioning them has anything to do with my argument. I mentioned comparable knives, marketed in comparable ways, at comparable prices. Emerson knives didn't happen to be included in that. If I have something to say about a knife or knives, then I say it.
You're right, every lock has pros and cons. Absolutely. But assume you're purchasing a folding knife, and your focus is strength + ease of carry. I assume that's why you would be looking for an "overbuilt" folding knife in the first place, and not to admire its "fit and finish", its "glass smoothness", flipping action, ease of disengagement, or other things that make it a fun toy to play with.
Yes, omega springs can fail, however note that when force is applied to the knife blade of an Axis locked knife, the springs themselves aren't the ones taking stress. Stress to those springs isn't going to be what causes failure of the lock. I assume you also don't trust other everyday items relying on even flimsier springs for their function.
Scurvy092 said:
I have a $15 Chinese neck knife that will pass any spine whack test.
shinyedges said:
We should all get opinels, the lock strength to dollar amount is off the charts lol
I thought the discussion had to do with one-handed opening folding knives that are designed & produced to be "overbuilt", and are purchased because of their supposed strength. If all knives were included in the discussion, there would be no point, we would all just shrug off folding knives as an entire category.
I can see an interest in "hard use" folder lock integrity, within reasonable parameters. First, the term "hard use" has to be level set. As has been repeated ad nauseum, knives are cutting tools. Using that to establish a boundary of sorts, we can rule out using the spine as a hammer or bludgeon. If we're looking at use as a cutting implement, examples of "hard use" might include camp tasks like stripping protrusions from a stick for use as a stake or spike, or deep notch or groove cutting in wood. I have used a ZT 0550 to break down a soft wood frame, which involved a bit of light chopping and notch cutting, as well as the kind of light prying done when separating cut portions from the material body. These are reasonable, and could be defined as "hard use" in relation to most EDC tasks.
In those applications, I consistently use a hammer grip, with pressure exerted on the lock bar. I've had a few occasions where there have been light spine contacts on backswings during light chopping, with no dramatic outcome.
I feel it may be relevant to note the flipper tab on the 0200, which should prevent cuts to the user in the event of lock failure in actual use.
Take this for what you will.
I don't think anyone's realistically thinking of using knives as such. If a folding knife can be used in that manner, it is certainly abuse, but also an indicator that the knife is literally 'over-built' - built in such a way that it will withstand actual abuse outside of what knives are required to do. Some cutting & light prying applications do put forces on the blade that's similar to pressure on the spine anyhow. Think of a knife blade stuck in wood, and tugging & twisting the knife to try to free it from the wood, for example.
Further, accidents & mishaps do happen where sharp pressure is applied to the spine. Of course that's not something to be expected, or something to necessarily consider when purchasing a knife. But if a consumer is purchasing a folding knife with its strength and user safety as a consideration, then it's not exactly irrelevant.
Again, if strength can be reliably had in an easier to carry package at a lower cost, why make more compromises than you need to.
